crawleysam Posted February 22, 2015 Share Posted February 22, 2015 So I got my Gt turbo on the road friday, and since driving it I noticed its severely lacking in power. Especially compared to my old GT which had no more modifications really Feels like the turbo has no kick, and the HI/LO modes are barely distinguishable. It compares more to my NA then my old GT Any ideas why? Not overly smokey or anything It has FMIC, dump valve, air filter and thats about it, but the dump valve doesnt really make a sound Only has standard boost gauge but it never reaches 0? Example of lack of power, was going up a not too steep hill at 40mph in 3rd, put my foot all the way down and the car wouldnt go any faster And before it wouldnt go past 80, just felt like had no power at all. Quite odd to find this. Also relative to my old GT it uses barely any fuel? Good thing maybe? Any advice or help would be great Thanks In advance, Sam Quote Link to post Share on other sites
Bean Posted February 22, 2015 Share Posted February 22, 2015 have you checked the timing? thats something i would have a look at and get a timing light on it. Quote Link to post Share on other sites
crawleysam Posted February 22, 2015 Author Share Posted February 22, 2015 I havent checked it no, but it seems to be running all good. Idles smooth and revs nicely just nothing to back it up Quote Link to post Share on other sites
Socks Posted February 22, 2015 Share Posted February 22, 2015 Have u got a boost gauge? Is it building ANYTHING? Boost Leak? Quote Link to post Share on other sites
5T4R7ET N/A Posted February 22, 2015 Share Posted February 22, 2015 If the boost gauge never reaches 0 then your not hitting boost. Check your intercooler pipes and vacuum pipes that go into turbo and solenoids. Quote Link to post Share on other sites
crawleysam Posted February 22, 2015 Author Share Posted February 22, 2015 On 2/22/2015 at 5:55 PM, Socks said: Have u got a boost gauge? Is it building ANYTHING? Boost Leak? Just the standard one in cluster, it does move it just doesnt reach 0, but Its probably not 100% calibrated anymore, i thought it could be that. It does have a blitz turbo timer fitted would that give any indication as to a problem? On 2/22/2015 at 5:55 PM, 5T4R7ET N/A said: If the boost gauge never reaches 0 then your not hitting boost.Check your intercooler pipes and vacuum pipes that go into turbo and solenoids. I thought it could be vac as the BOV makes nearly no noise, just a bit of sucking/whining from intercooler Quote Link to post Share on other sites
Socks Posted February 22, 2015 Share Posted February 22, 2015 Movement below 0 is Vaccum... (IE Before you come on boost) So your making NO Boost. If that gauge is accurate Sam... Boost Leak, would be my first port of call! Quote Link to post Share on other sites
Ollieh17 Posted February 22, 2015 Share Posted February 22, 2015 sounds like mine on two occasions, both times turbos were knackered Quote Link to post Share on other sites
crawleysam Posted February 22, 2015 Author Share Posted February 22, 2015 On 2/22/2015 at 6:03 PM, Socks said: Movement below 0 is Vaccum... (IE Before you come on boost)So your making NO Boost. If that gauge is accurate Sam...Boost Leak, would be my first port of call! I will check all the joinings tomorrow and see if there are any leaks On 2/22/2015 at 6:06 PM, Ollieh17 said: sounds like mine on two occasions, both times turbos were knackered Turbo would be a good call, but does it not have any signs like smokey exhaust or some noises? Quote Link to post Share on other sites
Ollieh17 Posted February 22, 2015 Share Posted February 22, 2015 Both times for me there was no smoke, because the turbo was making no boost. It just made a whinny noise. Would have to be a big boost leak to make no boost at all Quote Link to post Share on other sites
crawleysam Posted February 22, 2015 Author Share Posted February 22, 2015 On 2/22/2015 at 6:35 PM, Ollieh17 said: Both times for me there was no smoke, because the turbo was making no boost. It just made a whinny noise. Would have to be a big boost leak to make no boost at all I'll have a listen to the turbo tomorrow and see what noise it makes chief Quote Link to post Share on other sites
