Ive just wired in my emanage blue and all is going well. Ive seen a few people talking about wiring in an afr into the manage blue to data log and even use the auto tune function. I just wanted to know if there was any solutions to a diy harness. Or something cheap as im on a budget. Also any help with the auto tune function will help
Thanks
Turk
I've looked into it slightly. Something I plan to do with the emu. From what I seen you can hook up the 5v signal wire from a wide and controller using a shaved down R/C car plug
Then I needed a harness for my AEM UEGO wideband as I want to use it for data logging with EMU. Greddy sells the harness, but the price is quite high, so I bought Futaba servo extension cable that is used in R/C cars. You have to cut a small edge off from the plug and it will fit perfect. (already cut on the pic below)
129.jpg?dl=0
130.jpg?dl=0
