Sefton-EP91 Posted February 26, 2015 Posted February 26, 2015 Looking for the silicone hose that is used for oil drain from the turbo (90 degree hose) PM with what you have! Needed ASAP so will consider all that are offered! Cash waiting!
Paton Posted February 26, 2015 Posted February 26, 2015 I think I have one spare mate, will check when I get back from uni.
Idrees Posted February 26, 2015 Posted February 26, 2015 We have OEM Rubber hoses in stock along with Silicone hoses which can also be used with many bigger turbos. We have both types in stock so can be with you tomorrow.
Sefton-EP91 Posted February 26, 2015 Author Posted February 26, 2015 I'll be using a WEPR billet td04 so need one for that. My kit retains the stock drain pipe but I don't have it lol
curtis1932 Posted February 26, 2015 Posted February 26, 2015 I've just put a td04 on mate so i have 1 of thees u can have were abouts are u
Bean Posted February 26, 2015 Posted February 26, 2015 Cam skill stock the genuine Toyota ones. There 5 quid
_shaun_ Posted February 26, 2015 Posted February 26, 2015 It's a 19mm silicone oil hose you need. Just make sure it had the red lining inside. I got mine from eBay for like £13 found the oem rubber ones just go hard and britle after awhile
Idrees Posted February 26, 2015 Posted February 26, 2015 I'll be using a WEPR billet td04 so need one for that. My kit retains the stock drain pipe but I don't have it lol We have OEM return pipes in stock
Sefton-EP91 Posted February 27, 2015 Author Posted February 27, 2015 It's a 19mm silicone oil hose you need. Just make sure it had the red lining inside. I got mine from eBay for like £13 found the oem rubber ones just go hard and britle after awhileInternal diameter 19mm? Thanks
akyakapotter Posted February 27, 2015 Posted February 27, 2015 Internal diameter 19mm? Thanks£10.96 on ebay
Paton Posted February 27, 2015 Posted February 27, 2015 Yeah mine is OEM rubber actually so you won't be wanting that.
