GlanzaCanada Posted March 5, 2015 Posted March 5, 2015 Hey guys, so I placed a big order for the my 1997 glanza v, and when I ordered all my slotted and grooved rotors through id-workz I seemed to of made a mistake with the rear disc.To my surprise the car didn't have ABS like I thought, and now since I searched it the ABS box also isn't in the engine bay either...should of checked that before ordering.Anyways can I still use these ABS rear disc's even though I don't have ABS now. Or what do I need to take off or add to make the disc work?Appreciate any help! Quote
mikey4410 Posted March 5, 2015 Posted March 5, 2015 alsong as they fit up and dont obstruct anything they will be fine.they are still discs.lol Quote
JDMfreak Posted March 5, 2015 Posted March 5, 2015 think all thats different between them is the abs disc have the ring on inside for the abs sensor to pickup a signal,, as above what mikey said if they fit and have no issues may aswell use them Quote
GlanzaCanada Posted March 5, 2015 Author Posted March 5, 2015 Haha...I'm just wondering what the integral difference is between a abs rear disc and a non abs rear disc. Quote
GlanzaCanada Posted March 5, 2015 Author Posted March 5, 2015 Where is the ring located? Is it the gear like ring on the backside of disc? Quote
JDMfreak Posted March 5, 2015 Posted March 5, 2015 yes same as what you have at minute a ring gear on the inner parts of hub Quote
Idrees Posted March 5, 2015 Posted March 5, 2015 Just remove the ABS ring, pictured on the right disc above Quote
Ollieh17 Posted March 11, 2015 Posted March 11, 2015 Can you use non abs disks on a car that had abs but has been removed? Quote
JDMfreak Posted March 11, 2015 Posted March 11, 2015 (edited) Can you use non abs disks on a car that had abs but has been removed? yeah im sure it wouldn't cause any problems if the abs has been removed already Edited March 11, 2015 by JDMfreak Quote
