ep91 ordered wrong disc's!
Hey guys, so I placed a big order for the my 1997 glanza v, and when I ordered all my slotted and grooved rotors through id-workz I seemed to of made a mistake with the rear disc.
To my surprise the car didn't have ABS like I thought, and now since I searched it the ABS box also isn't in the engine bay either...should of checked that before ordering.
Anyways can I still use these ABS rear disc's even though I don't have ABS now. Or what do I need to take off or add to make the disc work?
Appreciate any help!
think all thats different between them is the abs disc have the ring on inside for the abs sensor to pickup a signal,, as above what mikey said if they fit and have no issues may aswell use them
  On 3/11/2015 at 12:11 PM, Ollieh17 said:
Can you use non abs disks on a car that had abs but has been removed?
yeah im sure it wouldn't cause any problems if the abs has been removed already
Edited by JDMfreak
