5e colin Posted March 11, 2015 Posted March 11, 2015 hey lads is this tig any good can i weld ss and aluminium with this 1 http://www.ebay.ie/itm/Welder-TIG-Pulse-arc-mma-welding-machine-mask-stick-inverter-hf-start-DC-200-Amp-/121428358919?pt=LH_DefaultDomain_3&hash=item1c45b1b707 Quote
AdamB Posted March 11, 2015 Posted March 11, 2015 (edited) No you need AC to weld alloys mate. You'll be looking at £750 + for a half decent TIG that will weld alloys. You can weld alloys with a MIG but the finish isn't no where near as good, if that helps. Edited March 11, 2015 by AdamB Quote
5e colin Posted March 11, 2015 Author Posted March 11, 2015 bummer tel me that this at least does stainless ??? Quote
AdamB Posted March 11, 2015 Posted March 11, 2015 Aye it will do steels, but don't expect it to give the penetration like it says it will do, ie 6mm. Will likely do 5-5.5mm. Also don't forget that if you want to crank the amps right up you'll also need a 32 amp socket or you'll forever be tripping the elelectrics in the house lol. Quote
5e colin Posted March 11, 2015 Author Posted March 11, 2015 ???? arnt al sockets in the house 16A ?? Quote
1990timeismoney Posted March 11, 2015 Posted March 11, 2015 http://victortechnologies.com/thermalarconthemove/htdocs/201ts.asp Had a guy do my work with this and was very impressed with the results. Quote
AdamB Posted March 11, 2015 Posted March 11, 2015 (edited) Aye standard households are 16 amp. You will trip that when you get to about 150-160 Amps, depending on your machine and the duty cycle. Depends really on your budget and what you're going to be using it for.Looking to use it to create stuff to sell then it's wise to invest in a good machine, something like Miller, Kemppi, Lincoln.For hobby use and mid range machine would be like R-Tech, Parweld, Thermal Arc, Everlast.Then below that you got your cheap nasty chinese crap from ebay that's horrible to weld with. That's before you get on to getting consumables such as the tungsten's, filler rods, etc. Also everyone benefits from a bench grinder as you will no doubt dunk the tungsten in the work a fair few times. Edited March 11, 2015 by AdamB Quote
5e colin Posted March 11, 2015 Author Posted March 11, 2015 thanks guys wont have that kinda funds spare for long time so will have to be something cheap ish to learn tiggin with good thing you mentioned a bench grinder i could use a bench belt sander would make my life so much easier to with pipe work Quote
Bean Posted March 11, 2015 Posted March 11, 2015 (edited) I bought this machine http://www.ebay.co.uk/itm/INVERTER-SOLDADOR-PROFESIONAL-SOLDADURA-SOLDAR-TIG-ACDC-ALUMINIO-200-AMP-230-V-/291401597746?pt=Habitaci%C3%B3n&hash=item43d8e38332 Yes its built in China but its not your usual rubbish. It is almost identical to a machine R-tech sell for more than double the price. But from them you get excellent customer service and a very good warranty. It depends if you want to take the risk.Ive had it just over 2 years ago now and it hasn't had alot of use tbh but its been great. 200 amp ac/dc pulse ect so it can weld most things you would want to. I took it to a good fabricator i know who uses an old Esab transformer tig and he said it welds as nice as his beast of a tig does. Things to consider price wise is that theres quite bit more to buy than just the welder, you need various tungsten's, different wires obviously, a decent sized argon bottle, regulator if the bottle doesnt have one built in, ceramics, collets, a decent mask, something to grind your tungsten with, gloves it all adds up to alot more than you think. Edited March 11, 2015 by Bean Quote
mark1991 Posted April 30, 2015 Posted April 30, 2015 I bought a Chinese ac/dc tig machine and so far it's been really good! I use some of the best machines at work but I can't fault the machine it does aluminium better than some of the machines at work! is much better than I expected Quote
5e colin Posted April 30, 2015 Author Posted April 30, 2015 cheers for the info mark if you could link me with a similar 1 that would be great Quote
