Currently got 4 of the water pump nolts out and im struggling like hell to remove the 5th one which (I THINK) is located underneath the engine mount..
Can anyone give me a few tips or suggestions to make this a little easier, cheers
put a jack underneath the engine and remove engine mount, you will need to lower engine a little with the jack from memory to get to the last bolt
You can take the hole housing off from the rear held on by 3 12s i think,I loosened the alternator as well,
Just noticed today, that my water pump seal is seeping a little bit from the top of the pump. Can you remove the pump and the housing easily just by loosening the alternator? Should it be done from under the car?
This sounds easier than removing the engine mount and lowering the engine to get the access to the pump bolts.
EDIT: I have Glanza if it makes the difference.
Edited by JayJ
