patman Posted March 18, 2015 Posted March 18, 2015 having to put my standard actuator back on for a while, but does anyone know about where the vacuum pipes go, On the standard actuator there are 2 ports I know one of them goes to the turbo but does anyone know where the other one goes to? As I haven't anywhere that it can go too.Thanks ladsPat Quote
Ryan_EP82 GT Posted March 18, 2015 Posted March 18, 2015 It just vents to atmosphere Pat! Near sure its the back one that you leave blank.Ryan Quote
patman Posted March 18, 2015 Author Posted March 18, 2015 Thanks ryan mate for the reply I did think of that but then though surely it couldn't but if it does like you say that's fantastic thankyou 👍 Quote
patman Posted April 3, 2015 Author Posted April 3, 2015 Hello mate just put my standard actuator back on got the hose going from the turbo to 1 port on the actuator and the other port on the actuator has been blanked off so I was told, I know you said leave it to vent to the atmosphere but are you 100% sure on this as I thought if you lefted it free it would cause a boost leak? Quote
5e colin Posted April 3, 2015 Posted April 3, 2015 (edited) ya leave 1 open to air otherwise its low boosting al the time i didnt have any spike isseus Edited April 3, 2015 by 5e colin Quote
patman Posted April 3, 2015 Author Posted April 3, 2015 Thankyou Colin mate I will change it then as its blanked off at the moment, I wanted to start running abit of boost now as on 1168km running it in, still on millers running in oil, I did notice there still isn't boost at 4k revs (doing what we talked about even though should be on 5k revs by now) Quote
Ryan_EP82 GT Posted April 3, 2015 Posted April 3, 2015 Yeah Pat the port that you vent to atmosphere would nornally be recirculated back into the efi pipe on the stock setup so no worries there.You still not making boost at 4k revs? Sumthin not right there Pat! Quote
patman Posted April 3, 2015 Author Posted April 3, 2015 Yeah that's the one ryan mate, I will take the blank off asap, when I brought the car and it had a hks actuator on it there was no boost then till 4k and a half then when it went on the rolling road, he adjusted the actuator so boost was coming in just after 2k and a half......now put the standard one back on today I'm not sure when boost should come in on these standard ones and knowing now I blanked off the other port on it as Colin said it will be low boost so not sure when it should be coming in on the standard one hope this makes sense Quote
5e colin Posted April 3, 2015 Posted April 3, 2015 2.500rpm it must be boosting and full boost at 2800/3000 for sure ( ct9 ) Quote
patman Posted April 3, 2015 Author Posted April 3, 2015 You hear the turbo on mine (ct9) spooling at 2.5000rpm mate Quote
patman Posted April 3, 2015 Author Posted April 3, 2015 You think mate mind you on idle it sits at around 900rpm you are getting me worried now :-p Quote
Ryan_EP82 GT Posted April 4, 2015 Posted April 4, 2015 So its spooling up at 2.5k but isnt fully boostin til 4? Thats strange Pat..get the hks one back on and wind it til your set for about .8bar and check when she comes on song. Should be fully boosting by 3-3.2k revs Quote
patman Posted April 4, 2015 Author Posted April 4, 2015 Must be the actuator mate the standard one, only payed a fiver for it on here ages ago, I put it back on for now due to (hope this makes sense) the hks one didn't have pivot thing where you clip the circlip onto, and of course my turbo wastegate hasn't got it pivoted on either so for the hks one on I was using a nut and bolt for now, also turbo is new on well refurbished by Liam d 1160km ago so can't be turbo mate Quote
patman Posted April 7, 2015 Author Posted April 7, 2015 Just an update lads like you said, left the port 2 on the standard actuator vented to air now have boost, coming in around I would say just after 2k revs, going to about 0.5 bar on gauge, obviously not booting it as still running in car Quote
patman Posted April 7, 2015 Author Posted April 7, 2015 Thankyou ryan mate and Thankyou for your help glad that's ok Quote
Calum122 Posted April 14, 2015 Posted April 14, 2015 The second pipe goes to the solenoid near the intake. This is the solenoid for the 'Hi/Lo' boost button. Quote
patman Posted April 14, 2015 Author Posted April 14, 2015 All sorted now mate I don't have hi-low boost but Thankyou anyway Quote
Calum122 Posted April 14, 2015 Posted April 14, 2015 Aye, which is why people say vent to atmosphere. But it was just incase you were wondering why. Quote
