Mikeyallgood85 Posted March 20, 2015 Posted March 20, 2015 As above my fuel light is staying on permanently and have a full tank! Can someone tell me what could be the cause? Cheers all Quote
gorganl2000 Posted March 20, 2015 Posted March 20, 2015 check the float in the tank and/or the wiring to itthe float maybe stuck/broken Quote
Arnold Posted March 20, 2015 Posted March 20, 2015 check the float in the tank and/or the wiring to it the float maybe stuck/broken +1 happens in my Astra fairly often. A few quick corners and it comes unstuck and the light goes out. Quote
daniel_g Posted March 20, 2015 Posted March 20, 2015 If you take the sender unit out of the tank and give it a wiggle will probably fix it. Quite common on starlets actually Quote
redz11 Posted March 20, 2015 Posted March 20, 2015 I have the opposite problem, my fuel light never comes on, since I ran out of fuel once... Haha Quote
daniel_g Posted March 20, 2015 Posted March 20, 2015 I have the opposite problem, my fuel light never comes on, since I ran out of fuel once... HahaCould try the same thing, take the sender unit out and move the float up and down, the light should go on and off. Quote
Mikeyallgood85 Posted March 21, 2015 Author Posted March 21, 2015 ^^ yours could also be fuse related Quote
