Arnold Posted April 9, 2015 Share Posted April 9, 2015 Hi all I've got a non forged 4E producing 218hp at 0.9 bar and i keep having oil leaks from my rocker cover. I'm regularly having the cover tightened or gaskets replaced, and it's leaked again! What could cause this to keep happening? I've also got a RW developments catch tank and "Race spec" cover fitted if it could be anything to do with that? Cheers for any help Quote Link to post Share on other sites
Phil Posted April 9, 2015 Share Posted April 9, 2015 Hi all I've got a non forged 4E producing 218hp at 0.9 bar and i keep having oil leaks from my rocker cover. I'm regularly having the cover tightened or gaskets replaced, and it's leaked again! What could cause this to keep happening? I've also got a RW developments catch tank and "Race spec" cover fitted if it could be anything to do with that? Cheers for any help Instant gasket required Phil Quote Link to post Share on other sites
mccartney11 Posted April 9, 2015 Share Posted April 9, 2015 id just use gasket sealer and be done with it:P Quote Link to post Share on other sites
maddox710 Posted April 9, 2015 Share Posted April 9, 2015 Make sure you seal both sides of the gasket with silicone, i.e against the cover and against the head. I had this problem of oil weepin all the time. Until I did this and sorted the problem straight away. Make sure you clean surfaces with brake cleaner Quote Link to post Share on other sites
