matthewthomas Posted April 10, 2015 Posted April 10, 2015 Fitted a hks fuel cut defender last night took it for a lil test run and was going ok in the hi rev range and not so good in the low range tryed to go out this morning and car wont idle right unless the revs are up a lil and when you throttle the car it doesnt go past 3k now and just makes poping noise Quote
gazza g Posted April 10, 2015 Posted April 10, 2015 bit of a bad idea to be honest, did you set it up on the dyno or with a wideband in conjuntion with a adjustable fuel pressure reg? if not and you have been boosting it you may have damaged the engine, best bet is to remove it and see how it runs, if its no better then i would look at compression testing Quote
matthewthomas Posted April 10, 2015 Author Posted April 10, 2015 Was running fine when i put it on Quote
matthewthomas Posted April 10, 2015 Author Posted April 10, 2015 Number 8 pal uplugged it n the can runs better but hit fuel cut thats y i put the fcd on Quote
matthewthomas Posted April 10, 2015 Author Posted April 10, 2015 When i look at the fitting online it shows the red wire to go to a black a yellow lead but wen i look online a guy fits it to a red and black on his ep89 should i put it on the yellow and black see how i go from there ? Or is the red and black the right one Quote
matthewthomas Posted April 10, 2015 Author Posted April 10, 2015 Hy take it out ive turnt my boost down on my car and still hit fuel cut sick of it if i turn it down any lower i be running no boost Quote
matthewthomas Posted April 10, 2015 Author Posted April 10, 2015 Not sure as ive not done the setting on my tru boost gauge did ask in here but no one commeted on it Quote
Ollieh17 Posted April 10, 2015 Posted April 10, 2015 Id fit a boost gauge to start with before playing with a fcd, you're gonna end up with a fucked engine Quote
