JDMfreak Posted June 12, 2016 Author Posted June 12, 2016 (edited) another little update the GT got new shoes brock deep dish 14inch wheels car drives a lot better with the 14s compared to the 15s plus having no power steering its a help On closer inspection of my gearbox seems i do have cups in the box so just need a couple of day off and gather all the bits i need to swap the box out while im at it i might put a new clutch in Edited June 12, 2016 by JDMfreak Quote
JDMfreak Posted July 1, 2016 Author Posted July 1, 2016 right update time sent the car in for its nct/mot failed on sidelight bulb bonnet latch and an imbalance on front shocks have it all sorted now so in for its re test should pass passed everything else and was complimented on how clean it was for its age i have another huge update for the car but you will have to wait till it arrives only clue im giving should help it on a bit Quote
SpikeyJp_68 Posted July 3, 2016 Posted July 3, 2016 (edited) right update timesent the car in for its nct/mot failed on sidelight bulb bonnet latch and an imbalance on front shockshave it all sorted now so in for its re test should pass passed everything else and was complimented on howclean it was for its agei have another huge update for the car but you will have to wait till it arrives only clue im giving should help it on a bitI'll guess either a 4EFE or FTE And remove that adverts ad pronto Edited July 3, 2016 by SpikeyJp_68 Quote
JDMfreak Posted July 4, 2016 Author Posted July 4, 2016 your spot on 4efe going to buy back my old white ep80 has been lying up last few months so will have everything i need to convert it from 1e 12v to 1.3 16v 4efe i stuck it up to see what i got offered only thing that caught my attention was a 00 corolla vvti 3dr 1.6 6speed Quote
SpikeyJp_68 Posted July 4, 2016 Posted July 4, 2016 your spot on 4efe going to buy back my old white ep80 has been lying up last few months so will have everything i need to convert itfrom 1e 12v to 1.3 16v 4efei stuck it up to see what i got offered only thing that caught my attention was a 00 corolla vvti 3dr 1.6 6speedWhat are you doing with the ep80 shell ? Always fancied myself a GT rep... Quote
JDMfreak Posted July 4, 2016 Author Posted July 4, 2016 probably break it will be full car minus looms and engine box tank fuel lines dash and some other bits but what ever i take outta it ill put my 1 litre stuff in Quote
JDMfreak Posted July 15, 2016 Author Posted July 15, 2016 well time for another little update after a few days of hardship with the gearbox swap finally have it with 5 gears turned out clutch was wanked so picked up a 5 speed box along with clutch flywheel and release bearing for €100 i did get to drive car before engine was pulled out so i knew box was good also passed its nct was a re test but only failed on small stuff the power bug is getting to me so that's next up some sort of engine upgrade the 4efe i was meant to buy has fell through he doesn't know what he is doing with it but for now the 1e will have to do more handling upgrades are getting done front arb and rear in the meantime a sneaky shot of it in my mates garage popped out the spots to give them a clean and noticed they are a 100w bulbs no wonder there so bright Quote
5e colin Posted July 15, 2016 Posted July 15, 2016 very goood plan do al the handling and brakes first then go poooower i did it the wrong way round and has cost me plenty of parts !!! Quote
JDMfreak Posted July 15, 2016 Author Posted July 15, 2016 going to upgrade master cylinder as the 1.0 is tiny and then do all the brakes i don't really wanna swap out rear axles as handbrake is spot on 3 clicks and is locked solid fronts will get new hubs and bearings all round so i can run vented and grooved discs like my glanza had front anti roll bar will have to be beefy trd id say is best bet and rear anti roll bar Quote
5e colin Posted July 15, 2016 Posted July 15, 2016 dont bother with front only as it will induce understeer if going hard my car is solid on the rear and soft ish on the front handles perfect also has to do with drinking style i mean driving style ha ha Quote
JDMfreak Posted July 15, 2016 Author Posted July 15, 2016 how can i go hard in a 1e haha i can get front arb for nothing so may aswell fit it what anti roll bar on rear you running haha i only drink weekend saturday and cars isn't touched till Monday or Tuesday Quote
Mikey22 Posted August 20, 2016 Posted August 20, 2016 Hi nice car,i am trying to make a rep same as you but dont know where to get body parts, where did you get yours thanks Quote
