Charlie28 Posted April 25, 2015 Posted April 25, 2015 Changed my coolant sensor now and the cars still running bad. Can only think the timing is majorly out. When you touch the throttle nothing really happens! Any idea's? https://vimeo.com/125990466 Quote
Rob H@RCH Engineering Posted April 25, 2015 Posted April 25, 2015 That sounds horrid id say there was something out somewhere! What els has been done other than the coolant sensor?? has it just been built or something? Quote
Socks Posted April 25, 2015 Posted April 25, 2015 Whats fuel pressure set too? Have u got a stock fpr to fit? Quote
Glanza-Ben Posted April 25, 2015 Posted April 25, 2015 Did you fit a new belt or just put engine in how you got it Quote
Charlie28 Posted April 25, 2015 Author Posted April 25, 2015 When I removed the belt I lined everything up, 4efte on cam pulley and crank to marks on oil pump. I also checked the cam shaft marks to make sure the dots where aligned. I'm going to strip it all down tomorrow and take another look Quote
