ok so i shortened the length of my actuator to 119mm which is about 1.2bar according to a website. but now its too short and wont connect to the turbo wastegate arm. What do i do? does anyone know the actial length to get over a bar of boost?
I personally think that site is off, and not accurate at all, the only way in knowing it's right is with a good boost gauge (not these shit cheap ones you get on eBay where the needle bounces around like its on crack)
I agree mate reason I said it was I set my hks actuator at 128mm (standard boost) and it was well out I didn't even have boost, so I just think the only other way to do it is set the actuator so it just clips on the wastegate and go from there using 3rd 4th gear (not sure about 5th) to get the boost reading on boost gauge, then shortening the actuator every two turns till you get the boost you want,
