  • 3 weeks later...
Hi all,
Here is a list i created when i was doing my n/a to 4efte swap. It will help all you guys that are planning to do your swaps in the near future. If there is any thing that needs adding please let me know . My personal most important thing was a decent set of tools. The last thing you want to happen is to have to get some to take you tool shopping halfway through because you haven't got something. Close second was telephone numbers. Helped me massively.
You will need:
Engine lift
A good trolley jack
Axle stands
Lots of cardboard to lie on or a car creeper
Engine Oil (if it hasn't already got it)
Gearbox oil
Coolant
A good set of tools
A 4EFTE engine & ECU
An n/a & turbo loom made or a Glanza engine & interior loom with the dash
The 4EFTE power steering pipe
A few of you to do it
Telephone numbers of people who can give advice or help
Lots of patience
To Do:
Remove oil
Remove coolant
Remove gearbox oil
Remove radiator
Remove exhaust
Remove Speedo cable
Remove accelerator cable
Remove petrol lines
Remove gearbox hydraulic line and clamp up.
Remove gearbox cables
Remove power steering pump feed
Remove battery and bracket
Remove brake vacuum pipe
Pull Amplifier power cable into car (if you have one)
Remove ECU
Pull old loom out of interior
Remove old sensor on firewall
Remove bonnet
Remove bumper
Jackup and place car on axle stands
Remove front wheels
Remove drive shafts from diff
Hook up engine lift and tighten
Unbolt engine
Lift out engine
Clean engine bay
Drop 4EFTE in
Jack up gearbox into postion
Bolt in and remove lift
Put drive shafts in
Fill gearbox with oil
Fit gearbox cables
Fit petrol lines
Fit gearbox hydraulic line and bleed it.
Fit power steering feeds to pump.
Fit brake vacuum pipe
Fit radiator
Fit FMIC or TMIC
Fit BOV or block off BOV hole
Fit radiator pipes
Fill radiator with coolant
Fit exhaust system
Fit Speedo cable
Fit accelerator cable
Fit 4EFTE ECU
Plug in Loom to interior
Fit amplifier power lead
Fit MAP sensor
Fit coil pack
Fit bumper
Fit bonnet
Fit wheels
Jack car off Stands
Remove axle stands and lower car
Fit battery
Remove the injector connectors
Turn key
Let it turn over for a few seconds
Connect injectors back up
Start engine and smile :)
Sportif 4efte
Edited by Sportif 4efte
  • 3 weeks later...
  • 1 month later...
  • 4 months later...
  • 3 weeks later...
Looks well that dude ! Cant wait to see the finished product.
Thanks mate, need to get my indicators sorted then brake lines going for bridgstone glow in dark braided lines..should look good at night when cars rolling.. :hi:
>https://www.youtube.com/watch?v=tFov7DXsZ00
  • 1 year later...
  • 2 months later...
  • 3 weeks later...
