Dan507 Posted May 7, 2015 Share Posted May 7, 2015 Sup guys, i have a cut out misfire problem on my glanza, just replaced the whole ignition side of the car with a TD ignition overhaul kit, cars getting fuel ok, pops and bangs so its running slightly rich. FCD is set to 1bar but it cuts out in the high RPM at about 0.6 barthoughts? Quote Link to post Share on other sites
tommyep82 Posted May 7, 2015 Share Posted May 7, 2015 did you change the coil and igniter mate, fcd wiring look ok? Quote Link to post Share on other sites
Dan507 Posted May 8, 2015 Author Share Posted May 8, 2015 No I didn't mate, I'll check those wires. Cheers Quote Link to post Share on other sites
5e colin Posted May 8, 2015 Share Posted May 8, 2015 turn the fcd of and turn your boost down to 0.8 see if its gone fcd might be acting up ? Quote Link to post Share on other sites
Dan507 Posted May 8, 2015 Author Share Posted May 8, 2015 also, its worth mentioning that it has a starting problem, it turns fine but doesn't fire right away Quote Link to post Share on other sites
mikey4410 Posted May 8, 2015 Share Posted May 8, 2015 only time I have had a miss fire is when coil pack went. Quote Link to post Share on other sites
Dan507 Posted May 8, 2015 Author Share Posted May 8, 2015 (edited) i turned the FCD right down to see if it was that, how it went about cutting out, isn't how it cuts out so the FCD is fine. For now i've turned the boost right down, its on 0.4 bar and it fine for now, i'll try changing the coil pack next thanks guys. Edited May 8, 2015 by Dan507 Quote Link to post Share on other sites
