GlanzaCanada Posted May 8, 2015 Share Posted May 8, 2015 Hey everyone, since we never had the starlet in Canada finding alignment specs for the chassis at an alignment shop are impossible. At the moment we went off a toyota tercel from the same year as my glanza v (1997)Does anyhow have alignment specs for the starlet/glanza?It's been about two weeks now and the car is pulling to right and feels a bit unpredictable at times. Quote Link to post Share on other sites
Amjad Posted May 8, 2015 Share Posted May 8, 2015 Settings I've found are good are neutral toe, -1.5ish camber Quote Link to post Share on other sites
5e colin Posted May 8, 2015 Share Posted May 8, 2015 0.5 toe is stock if it feels to nervouse just start opening her up till you feel she is more planted also adding caster make a better planted feeling to Quote Link to post Share on other sites
mikey4410 Posted May 8, 2015 Share Posted May 8, 2015 2 degrees front camber and toe of 0.7. Quote Link to post Share on other sites
GlanzaCanada Posted May 8, 2015 Author Share Posted May 8, 2015 Ok thank you for the help all! Quote Link to post Share on other sites
