jamesh Posted May 8, 2015 Posted May 8, 2015 (edited) Just want to clarify what this noise is and if its my tappets as i have checked the idle valve and injectors and its not them. also if u listen carefully when i rev it i have this other weird noise that comes from the alternator area? It happens around 14-16 seconds in the video https://youtu.be/SiYxEvFdIws Edited May 8, 2015 by jamesh Quote
Glanza-Ben Posted May 10, 2015 Posted May 10, 2015 Ticking noise sounds like a normal 4e and the other noise sounds like a bearing in the auxileray area whining Quote
jamesh Posted May 10, 2015 Author Posted May 10, 2015 Is there no fixing the ticking sound as can get annoying lol...where is that? Quote
jimmymac101 Posted May 10, 2015 Posted May 10, 2015 Ticking noise is the injectors mate ... They all tick common with starlets James Quote
glanzatd04l220 Posted May 10, 2015 Posted May 10, 2015 the ticking noise can also be the idle control valve. kevin Quote
jamesh Posted May 10, 2015 Author Posted May 10, 2015 Unplugged the idle control valve and wasnt that. So i take it i cant fix it to stop the noise? Quote
MARC MOSS Posted May 10, 2015 Posted May 10, 2015 Yea easy just take the injectors out completely your engine will be quiet as a mouse lolSeriously man, they all tick put a bigger exhaust on if it bothers you there isn't much you can do Quote
jamesh Posted May 10, 2015 Author Posted May 10, 2015 Haha!! Ok fair enough will just leave it be. Will just turn up the music even more Quote
