Gav7 Posted January 12, 2006 Posted January 12, 2006 Hi there I've just put on an hks backbox with a custom piping but im now hitting the fuel cut point, whats the best way to solve the problem please, any help would be good thanks.
SiCaln Posted January 12, 2006 Posted January 12, 2006 get a Fuel cut defender form HKS, or the better option is the Boost Cut Controller form Jam or Greddy
Gav7 Posted January 12, 2006 Author Posted January 12, 2006 thanks for the quick reply, how much would one of these set me back then. cheers
SiCaln Posted January 12, 2006 Posted January 12, 2006 HKS would be about £100, as would the other types but they are harder to get hold of, try gtturbo
SiCaln Posted January 12, 2006 Posted January 12, 2006 the Jam racing one is good and you can get it from their website
SiCaln Posted January 13, 2006 Posted January 13, 2006 yea u should that stands for Rising Rate Fuel Pressure Regulator, SARD to a good one
Ivan Posted January 13, 2006 Posted January 13, 2006 SARD do not make a rising rate fuel pressure regulator. SARD make a fuel pressure regulator at a fixed rate of 1:1 i believe.Sorry, just had to clarify that one as its allways missinterprited.Regards,Ivan
SiCaln Posted January 13, 2006 Posted January 13, 2006 ah cheers man sorry lol, who do make rrfpr's then?
raging_fifer Posted January 13, 2006 Posted January 13, 2006 so what happens when you hit the fule cut off is it un driveable because im going to get d-cat made up realy cant be bothered with all the hass but need more power!!!
gaz Posted January 13, 2006 Posted January 13, 2006 it hits an invisible barrier and jerks the car, its not good. then the car has to sort of gain speed again
Guest daveburwash Posted January 14, 2006 Posted January 14, 2006 With a fuel cut defencer you should have an uprated pump and a rising rate regulator. I sell all these. It should then be checked on a rolling road to check the fuelling
Gav7 Posted January 22, 2006 Author Posted January 22, 2006 Thanks Dave and thanks to all for the advice
