dannyboyep91 Posted May 29, 2015 Posted May 29, 2015 got a glanza at work. Will crank over but not start. No fuel or spark.done all normal checks.Compression is good, timing ok. Hence how we know its not got fuel and spark.have replaced distributor and coil just to cancel them out. Also borrowed a second ecu and still no start.its as if he cranksensor is dead even tho it hasnt got one if u know what i mean.Anybody had any Similar problems? Also forgot to add. There is no eml light on dash at all Quote
jellybaby Posted May 31, 2015 Posted May 31, 2015 Power to the ecu ? Check passenger side behind glove box. Quote
Sefton-EP91 Posted May 31, 2015 Posted May 31, 2015 As above, check fuses and earths! Ensure all plugs are connected properly etc! Quote
