turbominicooper Posted May 31, 2015 Posted May 31, 2015 as above, how much boost can pass through the TMIC before considering going FMIC (ie before seeing a loss in cooling performance)? cheers Quote
Gainzy Posted May 31, 2015 Posted May 31, 2015 I've read up to 1 bar, fmic's are much better imo Quote
5e colin Posted May 31, 2015 Posted May 31, 2015 i ran 1 bar +- on tdo4 stock topmount worked great and spooled a good bit faster then with the fmic after !!! Quote
turbominicooper Posted May 31, 2015 Author Posted May 31, 2015 Ah that's good to know thought they were only good at stock boost Quote
AdamB Posted May 31, 2015 Posted May 31, 2015 Take a read here: http://www.toyotagtturbo.com/forums/showthread.php?74284-something-interesting-and-concerning-about-the-stock-intercooler Basically, their shit lol. Quote
Amjad Posted May 31, 2015 Posted May 31, 2015 (edited) ^Agreed, mine couldn't take 0.8bar on a Mine's ECU (limp mode) Edited May 31, 2015 by Amjad Quote
5e colin Posted May 31, 2015 Posted May 31, 2015 ha ha and he proved the arc is worse then the oem 1 !!! nice 1 indeed Quote
Gainzy Posted May 31, 2015 Posted May 31, 2015 I would go for the rx7 tmic if you don't want a front mount, be great for quick spools Quote
AdamB Posted May 31, 2015 Posted May 31, 2015 The temepratures Tim was seeing is in the territory of engine melt down. Intake temps above 60 degrees tend to start causing damage. The only thing the 4E has in it's favour is it's such low compression ratio. Quote
