sosolid Posted June 1, 2015 Share Posted June 1, 2015 can the valve seals be changed without taking the head off? Quote Link to post Share on other sites
sosolid Posted June 1, 2015 Author Share Posted June 1, 2015 ok cool what would procedure be? Quote Link to post Share on other sites
Phil Posted June 1, 2015 Share Posted June 1, 2015 Compressed air or rope in the cylinder to keep the valve upOverhead spring leverSortedPhil Quote Link to post Share on other sites
Calum122 Posted June 1, 2015 Share Posted June 1, 2015 Used rope the other weekend. And a pair of pliers and a pair of helping hands. Easy enough to do. No need to remove cambelt from crank if it's all marked up properly. A tool to remove the collets is a much welcomed tool! Quote Link to post Share on other sites
Phil Posted June 1, 2015 Share Posted June 1, 2015 Used rope the other weekend. And a pair of pliers and a pair of helping hands. Easy enough to do. No need to remove cambelt from crank if it's all marked up properly. A tool to remove the collets is a much welcomed tool! magnet is perfect alongside the lever i found. but yeah you def dont want one in the sump Phil Quote Link to post Share on other sites
Calum122 Posted June 1, 2015 Share Posted June 1, 2015 Yeah I used a socket with a magnet inside that caught the keepers. Did lose a few so it's handy to buy some spares. Quote Link to post Share on other sites
sosolid Posted June 1, 2015 Author Share Posted June 1, 2015 ok cool so who wants to do it? lol Quote Link to post Share on other sites
_shaun_ Posted June 1, 2015 Share Posted June 1, 2015 i done mine last weekend and bought a blue point tool designed to just this. most my time was wasted trying to get the rope down the bores the actualy stem seals only took about 30seconds to change each. Quote Link to post Share on other sites
Calum122 Posted June 2, 2015 Share Posted June 2, 2015 Make sure you coat the new stem seals in oil before fitting. Quote Link to post Share on other sites
