hi mates,
Would like to ask the pressure relief valve on the block, what's actually his job?
My oil pump doesn't pick up oil after I did a general oil change service.
Browsed this link http://www.ukstarletowners.com/topic/72474-5efe-oil-pressure-problem/?hl=%2B5efe+%2Boil
one of the member said the pressure relief valve was full of gasket, thus I am wondering the pressure relief valve is to used to determined whether it wants to suck how much oil?
thanks mate...
remove sump, remove pressure relief valve, undo the circlip in the end and it will come apart, clean then re-assemble. plenty sealer at both ends of the sump as they are the worst bits to seal. never known them to struggle to pick up oil after an oil change, but if it still dont pick up oil, remove the oil pump, pack with grease and try again
Take off oil filter with a bit of hose over the filter mounting point pour oil down it from a heigh and keep cranking. This worked for me
thanks mate. This is what i do currently. But i don't wish to do it everytime when I do a general oil service where I need to take out my front bumper and intercooler...
  • 1 month later...
hey mates,
what may be the cause of it when the engine running hot, my pressure only 0.5 bar on my greddy oil press meter.
when i took out the engine oil cap, the oil is spitting out from the head :sad:
  • 3 weeks later...
What temp is the oil at when you say hot. And what grade of oil are you using. Also ambient temp where you are?
About 90 degree celcius. I'm using a 10w40.
