Socks Posted June 12, 2015 Posted June 12, 2015 Different part number...But both are compatible with each other yes! Quote
J40k-mo Posted June 12, 2015 Author Posted June 12, 2015 I've put an gt sensor on my glanza, n when I'm on low revs and lightly accelerating and backing off, it's eithrr on or off revs it kind of judders feels like your pressing and on and off switch haha. As daft as it sounds,, could ths be because it's not the right one ? Quote
daniel_g Posted June 12, 2015 Posted June 12, 2015 Is it set up properly?Does it still fault with the TPS disconnected? Quote
J40k-mo Posted June 13, 2015 Author Posted June 13, 2015 Would it run with throttle position unplugged? Got a problem with dizzy but think this is a different problem, just doesn't feel smooth, you have to positive with throttle and can't tickle it haha Quote
Bluebear Posted June 13, 2015 Posted June 13, 2015 Yeah, I have that problem too J40k-mo, gonna get a new TPS when I get paid this month to see if it cures the problem! Quote
J40k-mo Posted June 13, 2015 Author Posted June 13, 2015 Could the throttle position sensor, if faulty and giving off wrong readings to ecu, cut of the injectors? Quote
