ChrisssAhhh Posted June 15, 2015 Posted June 15, 2015 I'm having trouble trying to get my turbo to flutter, I've a hks ssqv at the moment and I took the vac line out of the back of it and blocked it and it still won't flutter also I swapped the vac onto the solenoid and from the solinoid so I could choose to use Bov or flutter, the bov works fine but it's slightly frustrating that it won't flutter, I've got a standard air box and blitz panel filter if that helps it's only running standard .6 on ct9 and jam manifold Quote
Johnboy GT Posted June 15, 2015 Posted June 15, 2015 I think you need to blank the intercooler pipe where the BOV goes. Could be wrong thoughJohn Quote
Jay2ohh Posted July 8, 2015 Posted July 8, 2015 Front mount and air filter help the noise but basically just don't run a blow off, blank it all off, it's just air recirculating back through the turbo and the blades chopping it up that gives it the noise instead of circulating and finding a route out which is the blow off Quote
JDMfreak Posted July 8, 2015 Posted July 8, 2015 you still running the standard efi pipe chris and stock hot pipe I looped my boost solenoid so it runs high boost blocked vacuum from in let and blocked off the elbow on my hot pipe and fitted a a filter relocation pipe out to behind grill at front that's was the handiest way to do it you can kinda see in this pic what I did Quote
Bug679 Posted July 11, 2015 Posted July 11, 2015 All I done was take the vac pipe off the dump valve and stuck a bolt in the end of the pipe. Worked for me anyway Quote
akyakapotter Posted July 11, 2015 Posted July 11, 2015 http://www.toyotagtturbo.com/forums/showthread.php?76514-flutter-or-dump....-how-about-both..-read-on Quote
MARC MOSS Posted July 11, 2015 Posted July 11, 2015 (edited) Just remove your air filter completely gauze the ct9 and block the dv hole she will flutter like a spring chicken on heat Just remember that your old turbo isn't really going to be happy about this, it may be fine it may not Edited July 11, 2015 by MARC MOSS Quote
