gorganl2000 Posted June 15, 2015 Share Posted June 15, 2015 anyone have any pictures or is there a dyi on fitting the oem 3 point rear strut brace? are the nuts/holes for the bolts at the bottom point already on the ep82/ep91 chassis or do you have to add these yourself? do you just remove the carpet and everything is already in place? just asking to see of they are any surprises before the installation process begins....best to be prepared as i didn't get a chance to look and wont before weekend thanks for any help Quote Link to post Share on other sites
Idrees Posted June 15, 2015 Share Posted June 15, 2015 They won't bolt in to the Mk 1 GT, but they're a straight fit in the Mk 2/3 and all Glanzas. Quote Link to post Share on other sites
Gainzy Posted June 15, 2015 Share Posted June 15, 2015 You will need bolts to bolt the brace in the middle a monkey could fit it in 5 minutes lol you will see when you look Quote Link to post Share on other sites
gorganl2000 Posted June 15, 2015 Author Share Posted June 15, 2015 They won't bolt in to the Mk 1 GT, but they're a straight fit in the Mk 2/3 and all Glanzas. thanks idrees...its a ep91....so will fit Quote Link to post Share on other sites
gorganl2000 Posted June 15, 2015 Author Share Posted June 15, 2015 You will need bolts to bolt the brace in the middle a monkey could fit it in 5 minutes lol you will see when you look great...thanks gainzy....just wanted to make sure....i always like to be prepared before i start a task Quote Link to post Share on other sites
morgey Posted June 15, 2015 Share Posted June 15, 2015 Wont bolt into the n/a's either. Turbos have extra bolts 90deg to the uk strut mount holes Quote Link to post Share on other sites
gorganl2000 Posted June 15, 2015 Author Share Posted June 15, 2015 Wont bolt into the n/a's either. Turbos have extra bolts 90deg to the uk strut mount holes always thought those were standard in every ep80/90 series...wasn't aware the n/a chassis didn't have these guess its a pretty easy fix if someone with a n/a wanted to install a rear strut brace though....just get them welded on Quote Link to post Share on other sites
morgey Posted June 15, 2015 Share Posted June 15, 2015 I think you can drill two extra holes and rotate the shock topmount in all honesty lol Quote Link to post Share on other sites
gorganl2000 Posted June 16, 2015 Author Share Posted June 16, 2015 I think you can drill two extra holes and rotate the shock topmount in all honesty lol lol you have a point not sure if it would affect suspension geometry though....would need to be done pretty accurately are there like dummy holes/impressions on the n/a rear shock towers that could help give an idea where to drill? Quote Link to post Share on other sites
morgey Posted June 16, 2015 Share Posted June 16, 2015 Wouldnt do much. The rear shocks dont affect any key geo, they litterally just do up and down motion so even if you did get the mounting postion slightly out i very highly doubt you'd ever notice it. Quote Link to post Share on other sites
