Before I start I know a piggyback would be better but I'm want to work with what I've got!
(ECU V.R.F V300 plug and play)
I am wanting to try to see if it will run a TD04 what will I need to try this? I have a wideband and boost gauge to monitor that but will I need to up the fuel pressure?
Bit of a silly question but am I just keeping an eye on AFR when on boost to make sure it's not too lean? And gradually uping boost pressure?
I did this on my old GT. Mines ECU. Just stay around a bar, i ended up maxing out the standard MAP sensor at around 1.1 / 1.2 bar and shat a rod.
I used an aeromotive FPR, AVCR EBC and a innovite wideband.
It's not afr u want to worry about its knock
so true chris
it seems people often concentrate on afr and forget about detonation
to me they go hand in hand....both need to be monitored and set up correctly for the tune
