Engine slightly knocking on accelaration
Im not sure of this but when im accelarating i sometimes hear some knocking/ping. I have forged wossner pistons and by them selves they already make strange noisestill they heat up but its common as i know others.
How can i be sure the engine is not knocking/pinging? Should i retard ignition by a bit and see if it does it or any other method?
Knock/det you will need detcans to hear that.
Could be bad fuel?
Or is it bearing knock?
Sure not bearing knock..while accelarating on low boost going 13.2 .. high 12s.. low 11s when hitting 21psi
Maybe just my mind
Maybe just my mind!
but if your sure its detonation are you using detcans to hear it??? or is this knocking just a noise?
