Duduglanza Posted June 26, 2015 Share Posted June 26, 2015 Sometimes it pops this code.. whats exectly the reason? Quote Link to post Share on other sites
JayJ Posted June 26, 2015 Share Posted June 26, 2015 The speed signal comes from the speedo to the ecu. If the speedo is not working, then there's cable, gearbox or speedo fault. If the speedo is working, then the speedo, signal wire or ecu is broken. Is your spd signal wire spliced or modified some way? Quote Link to post Share on other sites
Duduglanza Posted June 26, 2015 Author Share Posted June 26, 2015 Im running an emanage ultimate therfor it modified . It only flashes it rarely. Everything works fine.. Quote Link to post Share on other sites
JayJ Posted June 26, 2015 Share Posted June 26, 2015 maybe bad connection somewhere Quote Link to post Share on other sites
Duduglanza Posted June 26, 2015 Author Share Posted June 26, 2015 Will check again.. Quote Link to post Share on other sites
akyakapotter Posted June 26, 2015 Share Posted June 26, 2015 I've been trying to find the problem for 2 years now checked all wiring all fine so I gave up lol Quote Link to post Share on other sites
Duduglanza Posted June 26, 2015 Author Share Posted June 26, 2015 I've been trying to find the problem for 2 years now checked all wiring all fine so I gave up lolIt shows everytime you drive your car or every now and then? Mine shows up every now and then.. most of the time it do it while im on 5th and boost is building slowly... Quote Link to post Share on other sites
akyakapotter Posted June 26, 2015 Share Posted June 26, 2015 Yep every time I give it death I've put black tape over the light lol Quote Link to post Share on other sites
Duduglanza Posted June 26, 2015 Author Share Posted June 26, 2015 Speedo and tacho working fine? Quote Link to post Share on other sites
akyakapotter Posted June 26, 2015 Share Posted June 26, 2015 Yep every thing works on mine lol Quote Link to post Share on other sites
