Dansstarlet1996 Posted July 2, 2015 Posted July 2, 2015 Im going to be Dropping my ep91 40mm on lowering springs and im currently running speedlines with 195/45/r15 tyres, wanted to know will they catch the arches??Thanks Dan Quote
Bluebear Posted July 2, 2015 Posted July 2, 2015 If they do catch, they'll catch on the rear due to the rear beam axle and the suspension drop. Get a panhard rod as well to bring the axle back to centre after you put the 40mm springs on and you should be reet. Quote
Dansstarlet1996 Posted July 2, 2015 Author Posted July 2, 2015 I was looking at the whitline adjustable panhard rod? Which bit of the arch do you think it would catch on?? Quote
DavidAshton Posted July 2, 2015 Posted July 2, 2015 (edited) They won't catch and you will get away with not having an adjustable panhard rod. Edited July 2, 2015 by DavidAshton Quote
Bluebear Posted July 2, 2015 Posted July 2, 2015 Fair enough Dave! Must admit I wasn't sure with it only being springs. Quote
Dansstarlet1996 Posted July 2, 2015 Author Posted July 2, 2015 Ah perfect thanks guys! greatly appreciated! Quote
mart1 Posted July 3, 2015 Posted July 3, 2015 They won't catch and you will get away with not having an adjustable panhard rod.as above, that's what have being try to say on your other post. Quote
Dansstarlet1996 Posted July 3, 2015 Author Posted July 3, 2015 cheers bud think il try and get away with it then Quote
*Pete* Posted July 11, 2015 Posted July 11, 2015 Running tein springs 50mm on the rear just settled in really and with wheels 38 et with 195/60/14 which is slightly bigger with standard panhard rod and having no problems Quote
