Dansstarlet1996 Posted July 2, 2015 Share Posted July 2, 2015 Im going to be Dropping my ep91 40mm on lowering springs and im currently running speedlines with 195/45/r15 tyres, wanted to know will they catch the arches??Thanks Dan Quote Link to post Share on other sites
Bluebear Posted July 2, 2015 Share Posted July 2, 2015 If they do catch, they'll catch on the rear due to the rear beam axle and the suspension drop. Get a panhard rod as well to bring the axle back to centre after you put the 40mm springs on and you should be reet. Quote Link to post Share on other sites
Dansstarlet1996 Posted July 2, 2015 Author Share Posted July 2, 2015 I was looking at the whitline adjustable panhard rod? Which bit of the arch do you think it would catch on?? Quote Link to post Share on other sites
DavidAshton Posted July 2, 2015 Share Posted July 2, 2015 (edited) They won't catch and you will get away with not having an adjustable panhard rod. Edited July 2, 2015 by DavidAshton Quote Link to post Share on other sites
Bluebear Posted July 2, 2015 Share Posted July 2, 2015 Fair enough Dave! Must admit I wasn't sure with it only being springs. Quote Link to post Share on other sites
Dansstarlet1996 Posted July 2, 2015 Author Share Posted July 2, 2015 Ah perfect thanks guys! greatly appreciated! Quote Link to post Share on other sites
mart1 Posted July 3, 2015 Share Posted July 3, 2015 On 7/2/2015 at 7:31 PM, DavidAshton said: They won't catch and you will get away with not having an adjustable panhard rod.as above, that's what have being try to say on your other post. Quote Link to post Share on other sites
Dansstarlet1996 Posted July 3, 2015 Author Share Posted July 3, 2015 cheers bud think il try and get away with it then Quote Link to post Share on other sites
*Pete* Posted July 11, 2015 Share Posted July 11, 2015 Running tein springs 50mm on the rear just settled in really and with wheels 38 et with 195/60/14 which is slightly bigger with standard panhard rod and having no problems Quote Link to post Share on other sites
