FrozenJakalope Posted July 10, 2015 Posted July 10, 2015 Phil's got some 540ccs up in the for sale sectionhttp://www.ukstarletowners.com/topic/93655-big-stuff-forsale
ashep91 Posted July 10, 2015 Author Posted July 10, 2015 I thought the smaller tge injectors for tge application you want it for the better spray pattern ect?
maddox710 Posted July 10, 2015 Posted July 10, 2015 Yes that is correct that smaller injectors create a better spray pattern but that does mean that flow more cc of liquid
ashep91 Posted July 10, 2015 Author Posted July 10, 2015 I am on stock internals tdo4 so runing only one bar I might be able to get away with the stock injectors fro some things I've read but I think 430cc or 460cc are probably most suited
maddox710 Posted July 10, 2015 Posted July 10, 2015 Just get a set of green tops then. On stock you'll most likely be at 90% duty. I think the greens are 360cc
Phil Posted July 10, 2015 Posted July 10, 2015 Injector design determines spray pattern.I'd be surprised if a stock or 370cc is anywhere near as good as the decade newer design of the 430/540ccPhil
Phil Posted July 11, 2015 Posted July 11, 2015 I have 550ccThey will be the older design - at least I don't know of any new era 550sStill do the jobPhil
LukeColby Posted July 11, 2015 Posted July 11, 2015 I have been told there rx7 injectors red tops? I tapped the numbers into google and that:) Just kicking around as didont use them for my build Luke
Phil Posted July 11, 2015 Posted July 11, 2015 Yeh that's what they are 1980s technology but still works grand.Great on a big turbo - might be fun trying to idle on anything less than emanage ultimate Phil
LukeColby Posted July 11, 2015 Posted July 11, 2015 Haha awesome well will post if you need them mate for right price Luke
