leemillin Posted July 25, 2015 Posted July 25, 2015 guys, will this oil be ok for my n/a? http://www.ebay.co.uk/itm/MANNOL-CLASSIC-ENGINE-OIL-10-W-40-5-LITRE-/261905076560?pt=LH_DefaultDomain_3&hash=item3cfac25150 Quote
AdamB Posted July 25, 2015 Posted July 25, 2015 Probably. Would I use it or recommend it? Nope. Quote
morgey Posted July 25, 2015 Posted July 25, 2015 Grade wise its fine. 10w40 semi is what toyota recommend.But if you rag your car about get a half decent brand. Castrol mobilfuch Etc etcI run millers fully synth but thats in an engine revving to 8400. Quote
leemillin Posted July 26, 2015 Author Posted July 26, 2015 this oil any good? http://www.ebay.co.uk/itm/Mobil-Super-2000-X1-10w40-Part-Semi-Synthetic-Car-Engine-Oil-5L-5-Litre-/301696810230?hash=item463e87fcf6 Quote
AdamB Posted July 26, 2015 Posted July 26, 2015 As Morgey said really. If you stay with semi synth, then Castrol, Mobil are good choices. Quote
5T4R7ET N/A Posted July 26, 2015 Posted July 26, 2015 I would defo recommend mobil 2000 on a n/a starlet as i used it on mine. Quote
leemillin Posted July 26, 2015 Author Posted July 26, 2015 that link i put up on the mobil 2000, that for petrol or not? Quote
Calum122 Posted July 26, 2015 Posted July 26, 2015 I always use Silkolene for all my engines, all my engines are pushed fairly hard and none have ever given up the ghost. From my experience I'd always recommend the decent Silkolene stuff! But I'm a preventative maintenance man. I always rebuild the engine way before it would normally go...cheaper that way. But Mobil is good. Castrol are good. Depends how you drive really. If you wring its neck off then I suppose no oil is going to save it from the enivitable. But a half decent oil will do a better job. Quote
morgey Posted July 26, 2015 Posted July 26, 2015 that link i put up on the mobil 2000, that for petrol or not?Quoting the description in the link"An extra high performance motor oil for all types of modern vehicles including high performance and turbo charged engines. Delivers outstanding engine cleanliness and protection against wear at high temperatures and under severe operating conditions. Mobil Super S 10W/40 5L Car Engine Oil is specifically recommended for use in all high performance, turbo-charged petrol and diesel engines, as well as older normally aspirated models. Mobil Super S 10W-40 is an excellent choice for passenger cars, light trucks and vans" Quote
Chief Quimby Posted August 5, 2015 Posted August 5, 2015 Dont worry to much about what brand, they just need to be the right specs. I use 18pounds Worth 5Loil on my 413hp 5E engine. But i change it every 5000km. Quote
