Starletsr98 Posted August 2, 2015 Share Posted August 2, 2015 are ep91 n/a and gt turbo brake pads the same size i know the discs are diffrent Quote Link to post Share on other sites
glanzadude Posted August 2, 2015 Share Posted August 2, 2015 You sure the ep91 and ep82 discs are not the same as I swapped over discs from my Glanza to the gt. the pads are the same anyways Quote Link to post Share on other sites
morgey Posted August 2, 2015 Share Posted August 2, 2015 Turbo discs are the same unless its a very early mk1 N/a's have smaller discs. Pads i think are the same as i thinknits only the carriers that differe between them Quote Link to post Share on other sites
Starletsr98 Posted August 2, 2015 Author Share Posted August 2, 2015 thanks i went from ep91 na to mk3 gt turbo front brake set up and im after new pads so i was wondering if they are the same as gt discs are bigger Quote Link to post Share on other sites
glanzadude Posted August 2, 2015 Share Posted August 2, 2015 Pads are the same anyways as I swapped them over also Quote Link to post Share on other sites
Starletsr98 Posted August 3, 2015 Author Share Posted August 3, 2015 thanks Quote Link to post Share on other sites
