Rev counter in an NA
I've seen the tutorial on how to install one, but read someones comment saying theres a plug behind the dials that makes it easier to install? is it as simple and a few wires into sockets? also what brands/models of tachs are people using or know of that are good??
thanks Dan :)
  On 8/8/2015 at 4:21 PM, Dansstarlet1996 said:
Okay il have a look, i didnt need a shift light on the one im looking at so just need the tacho :) thanks colin
Assuning it's a UKDM P91, you want the plug on the right as you're looking at the clocks. There's a green wire on the right of the top row of the clocks, that's the tacho signal wire. Cut, strip n splice :)
Hell of a lot easier than tapping off the ECU as you're not having to run a wire behind the dash etc.
Edited by FrozenJakalope
