glanzatd04l220 Posted August 9, 2015 Posted August 9, 2015 Running td04l with all supporting modes ecu e manage blue, im using standard 295cc injectors but was looking to know if i put a set of these 370cc injectors in will the car run fine or will she need remapped?Kevin Quote
Whitenoize Posted August 9, 2015 Posted August 9, 2015 I wouldn't just fire in a new set of injectors and hope for the best get them tested first to make sure they are all working ok a failed injector could seriously fuck your engine Quote
glanzatd04l220 Posted August 9, 2015 Author Posted August 9, 2015 The injectors were flow tested, if i fitted the 370cc injectors would the ecu not just flow the same amout of fuel through them as the 295cc injectorsKevin Quote
