turbo-fever Posted August 14, 2015 Posted August 14, 2015 Had the aem wideband installed today and WOT I'm getting close to 11 which is OK and cruising is about 14 which I know is OK but on idle when it's cold it's at 15 as it starts warming up goes all the way to 10.5. Why so rich on idle but fine everywhere else ? Quote
patman Posted August 14, 2015 Posted August 14, 2015 I done a lot of research on this mate and a post as haven't had my aem wideband in long most people seem to say don't worry about idle figures etc as long as when your on WOT your getting around 11.5 on the wideband, but I'm hoping others see this and can give you more imput Quote
mikey4410 Posted August 14, 2015 Posted August 14, 2015 ok cold start 11.00 ishonce warm 14.0-16.5light cruising/steady speed 14.0-16.5wot should be ideally 11.0-11.5 Quote
Gilly Posted August 14, 2015 Posted August 14, 2015 Where in the exhaust is it mounted and what mods have you got? Quote
turbo-fever Posted August 15, 2015 Author Posted August 15, 2015 I done a lot of research on this mate and a post as haven't had my aem wideband in long most people seem to say don't worry about idle figures etc as long as when your on WOT your getting around 11.5 on the wideband, but I'm hoping others see this and can give you more imputThis is partly true but below 11 is extremely rich for idling Quote
turbo-fever Posted August 15, 2015 Author Posted August 15, 2015 Where in the exhaust is it mounted and what mods have you got? Followed the aem instructions so it's 36" away from turbo.Mods are:5efteTd05Zisco mani and downpipeRc 550 injectors FprStraight through exhaust Boost set at 1 barFmicRunning on emanage ultimate Quote
5e colin Posted August 15, 2015 Posted August 15, 2015 injectors are a bit over kil if your running only a bar !! smaller injectors will give better idle controle in the mapping that might be your isseu ???? Quote
turbo-fever Posted August 15, 2015 Author Posted August 15, 2015 Well they all set up on the car I am planning on upping the boost very soon, I'm just wondering if there is anything I can do in the meantime and how bad is it if I keep driving it Quote
