SOG33K Posted August 16, 2015 Posted August 16, 2015 Hi guys im after some info on how to remove the side rear quarter windows on my EP91 as ill be respraying it. Do you just use some heat and slide some fishing wire through and work your way around or is there a trick to getting them off? Any help would be appreciated. Thanks Quote
lukEp Posted August 16, 2015 Posted August 16, 2015 (edited) They have a rubber decorative trim which tends to get destroyed when cutting them out. But you can't really tell when bonding them back in. Cheese wire is better than fishing line. ;) Edited August 16, 2015 by lukEp Quote
SOG33K Posted August 18, 2015 Author Posted August 18, 2015 I might give it a go on my donor car first if its too hard ill leave them lol. Quote
fordie_glanzaV Posted August 18, 2015 Posted August 18, 2015 If u fuck the rubber then speak to local windscreen company they should be able to supply u with a replacement rubber which looks same as original Quote
SOG33K Posted September 2, 2015 Author Posted September 2, 2015 Ended up getting the windows out today pretty easily. I just used a heat gun to heat up the window and sikaflex. I then used a stanley knife to go all around the inside. The first one took me about 20 mins and the second about 10 once I knew what I was doing. It is fairly simple and doing it this way doesn't damage the window trim. Quote
