CTopZ Posted August 16, 2015 Share Posted August 16, 2015 Here's my problem, on way back from japfest I noticed that when I took my foot off the throttle the revs did not go down and seemed to just drive itself, I put my clutch down and the revs would slowly rise to around 2 to 3k revs, got home checked the throttle and it seems like the throttle pulley gets stuck slightly, as in the throttle doesn't go back to idle 100% and sticks right at the end, after a little nudge it would go back to normal. So tried adjusting cable to see if it would fix it but to no avail, I've tried lightly tightening the cable and lightly loosening the cable, also only seems to stick when engine is on, it's puzzling me abit tbh, not 100% sure what the culprit is? Any ideas? Anyone else had the same issue? Cheers Quote Link to post Share on other sites
jimmymac101 Posted August 16, 2015 Share Posted August 16, 2015 Try lubing up the cable and in side the plastic cover with gt86 or similar that may help James Quote Link to post Share on other sites
JayJ Posted August 19, 2015 Share Posted August 19, 2015 Yeah, had this issue twice. Just lube the cable and pulley Quote Link to post Share on other sites
maddox710 Posted August 19, 2015 Share Posted August 19, 2015 Happy days! cruise control Quote Link to post Share on other sites
CTopZ Posted August 19, 2015 Author Share Posted August 19, 2015 Haha I know, I've lubed it up and it has seemed to help Quote Link to post Share on other sites
Ep82gi Posted August 19, 2015 Share Posted August 19, 2015 Check the inside of the throttle body for corrosion around the butterfly seat Quote Link to post Share on other sites
