Hi all my bottom pulley started to make noises and it got worse you could rotate the pulley so far back n forth and it wobbled i took it of today this is it20150827_144207_zpsofolwsxf.jpg so what i ask is will a uk starlet one work or can i use a fensport aftermarket one or does it have to be an original one any help would be great as i use car daily for work thanks in advance
It will fit. But uk N/A and common aftermarket pulley do not use harmonic balancers.
have you seen the pulley up close ??? there is also a damper ( rubber ) in the 4efe pulley you can clearly see it on the back of them pullys they damp to :) :)
My mistake. My 4efe pully shat itself so may not have seen it... The 5efe pully I replaced it with wasn't dampened.
that is damped to my freind al e series are damped
only if its aftermarket pulley then its gone
Edited by 5e colin
