Hello guy I'm trying find some photos of what I can and can't remove fro the bulk head
The lots of pipes and valves and it just looks shit in my eyes can any one help.
Many thanks
Brake lines can be remade and hidden either lower down or go through the bulkhead and under the dash.
Aircon stuff can be removed.
Fuel filter could be swapped out for a better looking one (i.e earls) or hidden completely under the car.
Hide the map sensor
Loads can be done if you can be bothered lol
The only thing ive done so far to clear the bulkhead is get rid of the carbon cansiter and the shit going to the inlet.
As the lads above have said there is loads more you can do :)
Dan wit do you do to ditch the carbon canister just stick a breather on the pipe?
Colin can you block off all the vac on the inlet apart from the servo and map?
I just tucked the pipe out the way and let it vent to atmosphere, down by the OS wheel. You could put a 1 way valve on it i suppose but id be worried of it blocking and maybe build pressure in the tank?
Stuff on inlet i have are MAP, servo line, PCV, then stuff like boost gauge and dump valve are optional.
i forgotten the fpr !! my bad
but can be T in the map hose is 1 wanted i have it running like that atm no isseu
