morgey Posted September 8, 2015 Posted September 8, 2015 Heres a guide for you to follow, its a good place to start when modding the 4efte. http://www.ukstarletowners.com/page/articles.html/_/tuning-4efte/stage-1-200bhp-stock-engine-stock-turbo-r35Its not the only way but its tried and tested 👍 Quote
cory42 Posted September 9, 2015 Author Posted September 9, 2015 i havn't had a chance to remive the fcd yet but will let you know when its of, thank you morgey. Quote
patman Posted September 9, 2015 Posted September 9, 2015 Just don't boost it mate I know it's so tempting too but with what you set up is at the moment, you will thank me in the long run, and I'm sure everyone else who sees this will agree too :-) Quote
morgey Posted September 9, 2015 Posted September 9, 2015 Yep get the boost turned down to 0.75-0.8 and remove the fcd. Avoid boost as much as possible otherwise say bye bye to that engine. Quote
cory42 Posted September 10, 2015 Author Posted September 10, 2015 thanks for the help much appreciated, all going well ill remove the fcd later today and drop the boost level Quote
cory42 Posted September 11, 2015 Author Posted September 11, 2015 hi guys, as i haven't managed to get home of a standard actuator yet i had a go at lengthening my one and so far have got the boost down to around 10psi. will this be ok to boost on? thanks Quote
patman Posted September 11, 2015 Posted September 11, 2015 That's absolutely fine cory, now you understand how the adjustable actuator works, you don't need to now go ahead and get a standard one, 10psi is just under 0.7 bar I didn't think you had a boost gauge, so if you haven't mate how are you sure it's only 10psi? Also I want you to look at the fcd in the middle there is like a clock thing on it what setting is the fcd on, this is something we need to know Quote
cory42 Posted September 12, 2015 Author Posted September 12, 2015 yeah i have a boost gauge but its in psi not bar, the fcd is on 8 Quote
patman Posted September 12, 2015 Posted September 12, 2015 I would turn the fcd to 12 mate, so it's basically off, and I bet your can is running lean on setting 8 with no supporting mods. Quote
cory42 Posted September 12, 2015 Author Posted September 12, 2015 so if i turn it to twelve it wont affect the car, ill go do that now thanks patman Quote
patman Posted September 13, 2015 Posted September 13, 2015 It won't mate no it should be now almost back to standard this is a good starting point to do research and slowly build your car back up with more boost, when I had my hks fcd defender on setting 8 my sard fuel pressure regular was showing 2.4 bar on the dial on idle when warmed up (you will have the standard fpr on which is also 2.4 bar) anyway then I had a air/fuel ratio wideband fitted so on full boost (WOT) which means wide open throttle my wideband gauge was showing 16.2 which is way way wayyyy to lean, after putting the hks fcd back to setting 12 on boost my wideband gauge is now showing around 11.5 which is spot on. I hope this all makes sense mate Quote
cory42 Posted September 13, 2015 Author Posted September 13, 2015 yeah that make scene thanks for all the help, ill do some research and up the boost safely. Quote
