so I'd have to get the gt 4efte to fit a gt shell?
No you can put a Glanza V engine in a GT, use the thermostat housing from a GT so the plugs match.
If you need to you can swap the knock sensor if you need to but i think it was only the MK1 GT engine where it was different but im not 100% sure
