Still smoking on boost? Advice Needed!
As above, car is still smoking pretty bad on boost,
I have now uprated the valve stem seals and checked the intake pipes for any oil, which there is none and yet it's still smoky, not sure what it could be now,
Any ideas?
Ermm just sort of glazy, it's not blue from what I can tell. But i do know it's put little droplets of oil all over the rear. And Yeh mostly on boost, sometimes happens when I get to a junction/roundabout it will bellow out a load of smoke, but thats only on occasions.
Puzzled 😕
If its a standard turbo its a CT9, in all honesty youd be better sending yours away for a rebuild because its a minefield buying used CT9s, 90% of them smoke.
Or if you cant take your car off the road buy a cheap CT9 and send that away for a rebuild.
Or you could be running a TD04 and i wrote that for no reason haha
