enots Posted September 29, 2015 Posted September 29, 2015 Right fitted my ALK to the gt as i knew the bushes were worn etc all done easily enough bolted it all back on took it for a drive and disaster as my driver side wheel decided to make contact with my arch and destroy itself and the tyre. So assuming the because of my wheel width/widearches i removed the alk spacer thinking this would rectify the problem.no such luck. It seems my drivers side wheel sits further forward than the passenger. I'm assuming as ive removed the plates both sides should be pretty equal but they're not. Anyone have any ideas? Come across this problem before? Only thing i can think of is maybe i have a bent wishbone??literally stuck for ideas as the cars undriveable right now. Quote
morgey Posted September 29, 2015 Posted September 29, 2015 Try pushing the rear wishbone mount inward towards the center of the car? That might pull the wheel back a bit if my thinkings correct. Quote
enots Posted September 29, 2015 Author Posted September 29, 2015 Yeahh ive tried that doesnt seem to make any sort of difference Quote
5e colin Posted September 30, 2015 Posted September 30, 2015 if your wheel is forward then the i think your chassi leg is bent mate wishbones never bend forward the alk only moves your wheel a few mm so must be in pretty bad shape with your car Quote
enots Posted September 30, 2015 Author Posted September 30, 2015 It had crossed my mind only other thing i can think of is maybe the arches are slightly different size/shape and that whats making it seem further forward as it drives straight etc gonna have to do some digging i guess 😔 Quote
enots Posted October 1, 2015 Author Posted October 1, 2015 Are the ep91 and ep82 wishbones any different in size?or difference in what side i have them on? Just another thought as I've built it up I've got parts from here there and everywhere Quote
5e colin Posted October 1, 2015 Posted October 1, 2015 (edited) no ep80/82/91 are same fitment only front bush differs 34mm and 31mm but has no affect on alignment Edited October 1, 2015 by 5e colin Quote
enots Posted October 2, 2015 Author Posted October 2, 2015 Yeah what i suspected cheers for the info mate ! Quote
