StarletRick Posted February 26, 2008 Posted February 26, 2008 ive got a defi RPM gauge. its lush. ive got it wired into the RPM signal on the ecu and for some reason its saying im doing like 3 times the revs i actually am. ie 2k rpm = 6k on the defi. i know some of you NA boys have wired these up in your motors. and im wondering if there is another place to pick up the signal that might make it work? its all wired in correctly. the CU2 is registered as a 4 cyl engine. its just not working properly. any helps would be nice, wiring is ftl. Quote
keirz Posted February 26, 2008 Posted February 26, 2008 another place to pick the signal up is from the diagnostics box in the top right of the bay. place the wire in the ig- bit of a bodge way of doing it but it has worked for me in the past, if you still get an incorrect reading from here then i have no idea whats going off mate. Quote
StarletRick Posted February 26, 2008 Author Posted February 26, 2008 ill give it a go, i was just wondering if the signal gets amended anywhere between the ecu and the clusters..because its driving me fecking mad. Quote
Glanza_Ragger Posted February 26, 2008 Posted February 26, 2008 If youve taken a feed from the RPM signal wire on youre loom, that should do the trick bud ?Is it definately a good connection? and wrapped properly?Keirs's method is a good way to check if youre getting the proper reading..Is the gauge wired direct into the loom wire? or have you connected the control unit up to the rpm signal ? Quote
StarletRick Posted February 27, 2008 Author Posted February 27, 2008 its a defi, so it runs from the control unit, and that has one wire that ive wired into the RPM sifnal on the ecu loom. right next to the ecu plug.its being a prick. and annoying the shit out of me. although pretending its revving to 11k is ubes ^^ Quote
Glanza_Ragger Posted February 27, 2008 Posted February 27, 2008 although pretending its revving to 11k is ubes ^^Superbike stylee! just keep it fitted and amaze the passangers in ya car, just keep the music turned up so they cant hear the engine ;) Nah seriously, if youve taken the feed from the ecu rpm signal then it should be fine..Cant you reset the control unit and try and try setting it as a 4 cylinder again?If it still dont work...throw it in the nearest river Quote
RobSR Posted February 27, 2008 Posted February 27, 2008 if its from the ecu it should be fine...when i fitted the Bee*R straight off the ecu, it knew the exact rpm... Quote
Sparky Posted February 27, 2008 Posted February 27, 2008 If it still dont work...throw it in the nearest riverNoooo throw it to mee ;) Quote
