Scoobysvx Posted October 15, 2015 Posted October 15, 2015 For anyone who was wondering what is still available for the 95s, I've contacted my local dealer to get some new boots and output seals and also enquired as to what was available for the 4x4 system... Transfer box & prop are now discontinued.Diff is available for around £880Half shafts are too for around £250 eachI would imagine it's only a matter of time before they are discontinued too! 😔 Quote
daniel_g Posted October 15, 2015 Posted October 15, 2015 Its the not the end of the world if the rear end goes.AE86 axle would fit with minor mods.Or go all out and fit a rear subframe with IRS, from a ST205 or something.Thats why i launch mine at 6k side steping the clutch zero fucks given Quote
Scoobysvx Posted October 15, 2015 Author Posted October 15, 2015 At least there is options then with the Ae86... Do they share the same ratios do you know?Think I'd go all out like you say and fit a hole new subframe, make it worth while! Quote
richglanzav Posted October 15, 2015 Posted October 15, 2015 was funny when i had my ep95, we stuck it on a ramp got her up in the air and compared the diff and prop to my mates old celica gt4. its literally hilarious. i think you could shove a tonne of power through the celica drivetrain safely. Quote
daniel_g Posted October 15, 2015 Posted October 15, 2015 Weakest part is the halfshafts. My 85 has ABS so maybe a pair of 95 ones would fit?! Who knows.The 4paw prop look fucking solid, ive had 3 subarus and the prop on them all was thinner.Bit of chopping and welding and you could shoehorn a ST205 subframe in.. Quote
morgey Posted October 15, 2015 Posted October 15, 2015 Wouldnt you have to match the front and rear diff ratios otherwise youll be dragging around the back or trying to over take the front. Quote
Scoobysvx Posted October 15, 2015 Author Posted October 15, 2015 Wouldnt you have to match the front and rear diff ratios otherwise youll be dragging around the back or trying to over take the front.This is what I was worried about!Looking at that subframe its looks as if you'd have to remove or have a custom tank made as the front frame mounts would sit right in the way Quote
morgey Posted October 15, 2015 Posted October 15, 2015 The other option is do away with the front driveshafts, solid beam the prob and just go rwd. Quote
daniel_g Posted October 15, 2015 Posted October 15, 2015 Wouldnt you have to match the front and rear diff ratios otherwise youll be dragging around the back or trying to over take the front.Yeah man, pretty sure you can get a LSD for the AE86 axle which has a similar front ratio, so the VC doesnt shit itself.This is what I was worried about!Looking at that subframe its looks as if you'd have to remove or have a custom tank made as the front frame mounts would sit right in the wayIt would be a custom fuel cell job yeah.The other option is do away with the front driveshafts, solid beam the prob and just go rwd.Thats the way i was thinking tbh, got an engine and box combo in mind, nice Toyota one Then the rack becomes an issue etc.Aim of the game is dont fuck your 4paw haha... Quote
