As above, only need the fitting at the top where the pcv valve is. Preferably unpainted and clean
Edited by Ep91 kid
AN8 is too small. Way as well not bother.
You need to be using AN10 or AN12 ideally...
Cheers mate, I did actually mean an 10. Dunno where an8 came from 😁
  • 2 weeks later...
I've got a smooth cover here. Ideally wants stripping. But will need to be stripped for welding fittings on anyway
Fittings are less than a 10er. And i payed a 10er for some1 to weld them on...
So much cheaper than buying 1 done...
