Hello all I have a ep82 box on my glanza are glanza drive shafts different to ep92 as I struggling to get my glanza ones in the gear box
I have fitted a quife diff as well
seems to go in a little but wont go home fully would the little clip in the end of the shaft cause it to b a issue or do I have to use a bit of the hit and hope lark
Edited by jellybaby
it will be your diff thats making it hard to fit your driveshafts every aftermarket starlet diff seems be very tight, wait till you have to remove them from your diff thats when the headache begins.
As above mate, I bought a gearbox with a Quaiffe ATB diff. One of the shaft cups was still in the box and I needed to change the shaft seals and use my original shafts. MY GOD it was a slag to get out, felt like I was going to shatter the gearbox case before it went lol!
