Madge1980 Posted November 2, 2015 Posted November 2, 2015 Wondering how much a fair price would be for parts only to convert auto to manual. Had a quote of £600 for all parts required. Don't know if this is a bit steep as I've seen boxes only for £150. Thanks for any help/advice. Quote
lukEp Posted November 2, 2015 Posted November 2, 2015 GearboxManual selectorManual selector cablesFlywheelclutchMaster cylinderslave cylinderGearbox bolts flywheel bolts clutch boltsyou need to modify the ignition barrel and gearbox wiring. Quote
Madge1980 Posted November 2, 2015 Author Posted November 2, 2015 GearboxManual selectorManual selector cablesFlywheelclutchMaster cylinderslave cylinderGearbox bolts flywheel bolts clutch boltsyou need to modify the ignition barrel and gearbox wiring.Thanks for that fella. Ive got a fairly good idea now what parts I need and im pretty confident in doing the job myself just wondering what is the best route to go down for parts. Would it work out cheaper to buy a n/a starlet thats going cheap or buy all the parts separate. Quote
lukEp Posted November 2, 2015 Posted November 2, 2015 NA gearbox are weaker and have a smaller clutch, depends what power you want. If your thinking about just using a donor NA because of your budget a corolla 1.3 will do as well, you might be better finding a 6speed Corolla G6 just for the wow factor. Or find a yaris tsport gearbox as they have 4.312 final drive you'll still need a Starlet bellhousing but you could always be the first person to do it. I've actually got all the parts but can't be arsed being unique. Tops out @ about 140 mph with the Glanza rev limit coupled with an LSD (also got) would be a quick quarter mile. Quote
Madge1980 Posted November 4, 2015 Author Posted November 4, 2015 Haha love the fact that you can't be arsed to be unique Thanks again for the info I wasn't aware the n/a parts were smaller and weaker. Think I shall just purchase a standard glanza manual box and clutch as I am not planning on running massive power, just hoping around the 200bhp mark. Quote
5e colin Posted November 4, 2015 Posted November 4, 2015 na box will hold 200 bhp more and its a tikking timebom if i where you id look for a cheap as NA p9 starlet for 200/300£ but invest in a 4efte fly and clutch the rest can be na no bother Quote
